ir 2270 print quilty issue
  • wellrajive
    • Oct 2013
    • 31
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: ir 2270 print quilty issue
    Look's like a copy to me and not a print.
    Probably bias problem.Arcing on drum or developer.
    • bineeshgeorge
      • Jul 2009
      • 107
      Replace the spacers( may be yellow) in the developing unit.
      • allan
        RTFM!!
        • 5462
        Look at the pattern interval. It would probably be the diameter of the drum. Snakeskin pattern happens if the development bias leaks to the drum earth.
        The drum does not colect charge in those time instances.
        Whatever
        • Matoku
          • 173
          Originally posted by wellrajive
          hello friends pls help me. Print quilty problem in ir 2270 [ATTACH=CONFIG]29884[/ATTACH]
          it probably either the spacer bearing crack or it stars to jam or sometime it voltage leaks.
          • THUK
            • Jul 2008
            • 195
            Hi also check the Primary charge roller.
            • Canuck
              Tech Specialist
              • 1713
              Dev spacer issue. Common on np1020(remember?)...lol
              • zoraldinho
                • Mar 2008
                • 5015
                Nailed it!
