IPF8300 print head question
  • jumeda33
    • Jul 2015
    • 55
    [Misc] IPF8300 print head question
    Hi everybody. This is my first post on this site so I hope I am doing it right. I have an IPF8300 that kept giving me all kinds of print head codes. Was on phone with Canon and they can't go any further with me. Thanks to finding this forum and after having a service tech come out it seems as if I need the QM3-3121 board. Here are my questions. From what I see I will have to go through the replace print head routine to drain the print heads. Can I reuse them as long as I put them back where they came from? I am pretty mechanically inclined, will I be able to replace the board myself? Where can I buy the board at a reasonable price?
    Thanks to all for your help. I really appreciate it.
    David
  • teckat
    • 16083
    Re: IPF8300 print head question
    David
    Is there a guarantee from Canon or Service Tech that this part will Fix your issue
    if so >>>>>>>>>>
    if u have never removed the "Carriage Unit"
    have the service tech replace the "Carriage Relay PCB"
    -this is no walk in the park process-
    QM3-3121 ---cost 84.00
    http://www.iteminconline.com/qm3-3121-010_qm3-3121-010-qm3-3121-000-canon-ipf8300-carriage-relay-pcb.htm?source=froogle&gclid=Cj0KEQjw_rytBRDVhZeQr bzn_q0BEiQAjnbSHAsU8_FEgt6MwCGO9gfGilKeG-XB2XBecWHHBg4n9MEaAlcu8P8HAQ
    • jumeda33
      • Jul 2015
      • 55
      if so >>>>>>>>>>
      Thanks teckat,
      Sorry if you get this twice. I didn't see my own reply to you so I thought I would send it again.
      No one will guarantee the fix but thanks to this forum and a service tech coming out to look at the plotter to give us a quote it all points to the board. I found some instructions somewhere on this site but one of my questions that Canon would not answer for me was can I replace the printheads that I take out as long as I put them back in where they came from? They are both brand new and I really don't want them to go to waste. I am pretty tech savy and I can't really afford the approx. 1300.00 they want to fix it.
      Thanks,
      David
      • teckat
        • 16083
        Thanks teckat,
        Thanks,
        David
        Did tech tell u what the ERROR Code was ???????
        NOTE:
        When Carriage relay PCB or the Carriage unit have been replaced.
        Take a look at the attached photo of the carriage relay PCB. The image was taken from the back of the machine. The left of the image is towards the carriage home position.
        So you must stand at the back of the machine looking over the carriage relay PCB to be oriented like the image.
        All of the cables that go to the main controller have the blue writing facing the right. All of the cables that go to the print head have the blue writing facing the rear of the machine.
        dont' remember if u will have an issue with the print heads/ there is no caution procedure on replacing Carriage relay PCB when u remove Carriage Unit
        imagePROGRAF_Major_Component_ID_and_Replacement video
        https://www.dropbox.com/s/s5qfj89p1z...ement.exe?dl=0
        Download and unzip the above file. Then click the RUN.html file to launch the video.
        Scrool to page 3> select Menu>Under Major Componet Replacement > select ipf8000 series> select Carriage Unit /Print Head removal> will show removal procedure.
        Don't use Firefox to open/run .html --use IE
        • jumeda33
          • Jul 2015
          • 55
          Hi teckat,
          Thank you so very much for that very informative video. To answer your question about the error codes etc... The original problem gave no code. Just said left print head error and would even let me work the control panel. I had to go into service mode so it would let me get to the replace print head menu. So I did that with Canon tech support help. I called them when my new print head arrived and they talked me through replacing it using service mode. All is well at this point until I go to print something and I get the 2F48 code, right print head, which I had replaced about 6 months ago. Also I am thinking no way two print heads go at one time. So, being under warranty I replace the right print head again. Next thing you know I get a 2F43. Ended up having a local service guy come out and he wasn't sure so he speaks with another guy at the office and they feel it's the board.
          I do have a couple of questions about the video. 1) Is there actually a Drain Print Head option in the menu or is that the same as the Replace Print Head option which also drains them?
          2) Do I have to remove the whole carriage or can I replace the board at the point where they remove all the connectors from it?
          Seems to me they don't really explain that part and that it is more to actually remove the carriage. Looks to me like I could stop at the point where the covers and ribbon cables are removed and replace the board right there.
          Thank you so much for your help.
          David
          • teckat
            • 16083
            Hi teckat,
            David
            Believe you can just replace the board when visible/ & not have to complementary remove carriage ./ 3 page pdf attached
            of for full book-----------------------------------------
            copy and past below into browser menu
            canonipf.wikispaces.com/file/view/ipf8300+Service+Manual.pdf
            • hidius
              • Jun 2015
              • 128
              if print head doesnt fix it .. replace the carriage relay pcb
              • teckat
                • 16083
                poster replaced print heads/ has the carriage relay pcb in hand
                did you read posters reply's
                • hidius
                  • Jun 2015
                  • 128
                  i thought he replaced the print heads only .. didnt realise he had a pcb as well lol .. my bad
                  • jumeda33
                    • Jul 2015
                    • 55
                    Thanks for the help. I have one question. I have replaced both print heads within the last couple of weeks. Can I drain them, change the board and put the print heads back in as long as I put them back where they came from? If not, I think I need to get Canon to replace them under warranty but I would rather not go through that fight.
                    Thanks,
                    David
                    • jumeda33
                      • Jul 2015
                      • 55
                      Hi Teckat,
                      I really appreciate your help and documentation. I think I can do this. I am going to order the board from the link that you sent me. My only other question (I hope) is after I drain the heads, can I use them again as long as I put them back where they came from. The heads are new and I really don't want to have to fight with Canon about getting them replaced under warranty if I can just use them again.
                      thanks,
                      david
                      • teckat
                        • 16083
                        Hi Teckat,
                        thanks,
                        david
                        Sorry, don't want to give u a go,
                        never did that exact procedure before ( drain,remove new heads,replace pcb,re_seat new heads, etc. )
                        nothing in manual about procedure/ can u ask Canon ??
                        • jumeda33
                          • Jul 2015
                          • 55
                          I called them the other day about it. The first question was if I was an authorized tech. I said no and they refuse to give me an answer. They said they are not techs but only there to help troubleshoot what something may or may not be. They said I would have to ask a certified tech. Well I just had a tech in here and they wanted 1500.00 for parts. (relay cpu, two printheads, one maint. cart.) then plus labor. I just don't know how much info the old board keeps about the print heads. I am hoping I can put the new board in and then put the print heads back in. Maybe someone watching this thread can answer. I ordered the new board today.
                          Thanks again for all your help.
                          David
                          • teckat
                            • 16083
                            how many days have elapsed on the installed print heads_?
                            Is your printer stuck in an error_?
                            • hidius
                              • Jun 2015
                              • 128
                              Thanks,
                              David
                              From what I remember .. The print heads can kill the boards but the boards can't kill the print heads .. So if you have replaced both print heads to try and fix the error but it still erroring then yes you can re-use those 2 print heads.
