Ir adv 6255 (not waking up from sleep mode)
  • gksapple
    • Apr 2014
    • 116
    [Misc] Ir adv 6255 (not waking up from sleep mode)
    HI
    IR ADV 6255
    MACHINE IS NOT WAKING UP FROM SLEEP MODE ,every time when its goes to sleep we have switch off and switch on to use machine
    *updated the firmware to latest MN con 18.02 but no use still in the same condition
    looking for some suggestion
  • mramlawi
    • Jul 2011
    • 838
    Re: Ir adv 6255 (not waking up from sleep mode)
    hi change the Main Control Board and it will works .since a week happened same problem with me i debut in the power supply first then i realized its the Main Board i changed it and it works normally
    Distinguished road makes you jewel in rough
    • teckat
      • 16083
      Originally posted by gksapple
      HI
      IR ADV 6255
      Try & remove/clean/ re-seat RAM Dimms on MN-CON1
      or
      Replacement of Right Support 24V Supply==FC9-5007-000
      #32 in pic
      • mramlawi
        • Jul 2011
        • 838
        the weird thing that the machine is brand new and it just work 13000 copies and i changed the main conrtol and it works must be some updates to this or dont know the reason if any one know i will be thankful
        • teckat
          • 16083
          NOTE:
          You may just have some poor connections into that board/
          did / are you able test removed board on another printer to create the issue
          • mramlawi
            • Jul 2011
            • 838
            Originally posted by teckat
            NOTE:
            Yes i tried the part on another machine and it works then after a few hrs made same problem really weird its a brand new machine must be some bulltin for this issue
            • teckat
              • 16083
              Only thing posted for symptoms is Right Support 24V Supply replacement.
              • gksapple
                • Apr 2014
                • 116
                HI
                IS THAT MCB 1?
                • gksapple
                  • Apr 2014
                  • 116
                  Replaced the full power supply(swapped from another working machine)but still not resolved
                  try & remove/clean/ re-seat ram dimms on mn-con1
                  or
                  replacement of right support 24v supply==fc9-5007-000
                  #32 in pic
                  • teckat
                    • 16083
                    Try inspection and re-seating all components on the controller
                    if applies
                    turn "off" the option "Reject SNMP Packets While in Sleep Mode
                    Settings Registration > Network > SNMP Settings > Reject SNMP Packets While in Sleep Mode. [ on / off ]
                    set "Sleep Mode Energy Use" to "low"
                    Did you Set a Time for the Device to Automatically Exit Sleep Mode
