Image Runner IR1730 restart
  • Tuga
    • Mar 2012
    • 35
    HI
    I have a ir1730 when printing restart, but photocopy and send scanner.
    can someone help
    thanks
    Tuga
  • teckat
    • 16092
    Re: Image Runner IR1730 restart
    Originally posted by Tuga
    HI
    can someone help
    thanks
    Tuga
    please explain -- you mean printer resets or restarts
    • Tuga
      • Mar 2012
      • 35
      HI when I print the machine turn off and back on again
      • teckat
        • 16092
        the power switch can't turn off and back on by it self---------------
        Remove > clean> re-seat Memory Dimm ??
        Try Performing a Dram Test in Service Mode
        The Dram test does not affect any registered one-touch buttons or network settings on the imageRUNNER.
        To preform the Dram Test:
        Enter Service Mode> Test Mode> 1> Dram Test 1-2> 1.
        This will take about 5 minutes to complete.
        Then repeat the steps and choose Dram Test 2.
        Reboot the machine at the end of the test.
        u mean the control panel goes off>on
        or printer powers down & back up ?
        have u checked or monitored your outlet for correct voltage output or voltage drops ?? & proper Ground between Neutral = 0v +/- 0.5v Max
        is this outlet a dedicated one ( only for printer )
