IR C3200 printing problem
  • regalcopy
    • Oct 2007
    • 58
    Canon ir c3200 not printing
    I have this ir c3200 with n bootrom. I can scan and make copies. When i send a print it shows processing & waiting to print but the print never comes.
    I have internal print board (fg3 2729) & boot rom is 70.01n.
    I have tried ps/pcl with lpr / raw setting in printer driver. All tried but no print.
    Is there problem with bootrom.
  • nivssluck
    • May 2008
    • 228
    try to check if there is no pending jobs...
    • welshman
      Technical Support Manager
      • Oct 2007
      • 91
      try using ufr2 driver
      • regalcopy
        • Oct 2007
        • 58
        i've tried all drivers. m/c is not printing ps/pcl config prints from machine as well.
        • alex@wocltd.com
          • 430
          swap out the surf board.....
          • regalcopy
            • Oct 2007
            • 58
            Canon 3200 color not printing
            Swapped the surf board, boot rom, rechecked on all drivers, but no print.
            I can do pprint & all other print on service level1 from machine.
            report setting option - network setting print - i can print.
            report setting - printer-ps & pcl - font & configuration i cannot print
            what does this mean.
            • alex@wocltd.com
              • 430
              presume you have tried boards & boot rom by this stage in another machine?
              latest firmware?
              tried via different pc?
              done mmi clear?
              • welshman
                • Oct 2007
                • 91
                check the machine has system software installed for a network machine
                *2+8* then copier then version look for a system section and make sure it maches a network system rom version
                if a copier system rom is used then it will never print
