How to remove stapler option on iR Adv. 5030
  • mynameis
    • Jun 2015
    • 78
    [Misc] How to remove stapler option on iR Adv. 5030
    Hey guys.
    Need to get to the toner hoppers. Therefor need to remove the inner right covers...
    Seems impossible to get there without removing the stapler option (marked with red square in pic).
    Did not find anything about that in the sm or Elektrodok.
    Anyone got a manual for that? Or can help otherwise?
  • amraklve
    • Jul 2015
    • 17
    Re: How to remove stapler option on iR Adv. 5030
    Need to remove the finisher to get to the hoppers. Should be a few screws and two connectors and it should slide out the front of the device.
    Sent from my SM-G900I using Tapatalk
    • amraklve
      • Jul 2015
      • 17
      Remove screw bottom right of the red square and the locking piece at the bottom left of the square. Two connectors connected near top right of the square then pull inner finisher forward
        • 2621
        inner finisher install guide
        Inner Finisher-E1_SM_E_Rve0.pdf
        • mynameis
          • Jun 2015
          • 78
          Thanks guys, i got there and could remove CMY toner hoppers.
          BUT i am now stuck with the K hopper.
          It is assembled to a grey plastic part, and the service manual does not refer to that part...what do i have to do, to get the K hopper out...
          See pics attached, i marked the "blocking" plastic part.
            • 2621
            The instructions are here, pay attention to the "caution" section.
            hopper.pdf
