ImagePress C1+ weak Yellow
  • mynameis
    • Jun 2015
    • 78
    [Misc] ImagePress C1+ weak Yellow
    Hey guys.
    A customers C1+ suddenly droped down in density of yellow.
    First changed developer filling -> no change.
    Then changed developer unit, and developer filling -> no change.
    Strange thing besides that: When initializing Yellow, E020-0586 appears, which refers to the clear toner dev....
    Second attempt to init works.
    CM and K are all good...
    Any ideas?
  • mynameis
    • Jun 2015
    • 78
    Re: ImagePress C1+ weak Yellow
    Recallibrated RIP - no change.
    Strange aswell: After INIT the fresh DEV, yellow gets even paler.
    Yellow is now at approx 20% density, when printing PG5 with 255 dens-Y
    No one an idea?
    • teckat
      • 16083
      No one an idea?
      Performing a Developer Change on the imagePRESS C1 or imagePRESS C1+/and Clear Developer. see pdf
      some techs skip steps------------
      E020 - 0586 error code is indicated after replacing Y/C/M/K starters.
      This error code is referring to the Clear Toner (L) patch which is not measured at the referenced value by the patch image read sensor.
      In a couple of cases, replacing the Clear Toner starter resolved the error code.
      Developing BIAS Input Assembly resides on the front plate of the P-Kit.
      When the Developer Units rotate and are positioned for development, the BIAS tab rubs against the Developing BIAS Input Assembly to receive the developing BIAS.
      The part number is FM2-2662-000.
      primary and secondary transfer rollers
      • mynameis
        • Jun 2015
        • 78
        Thanks Teckat.
        Wouldn't the Developing BIAS Kit, aswell as primary and secondary transfer rollers affect all colours - and not just one?
        • teckat
          • 16083
          Thanks Teckat.
          did u follow procedure on Starter Replacement ? or did u wing it ?
          Yellow unit must make contact with bias tab on rotation
          Is Y Dev> receiving Y Toner
          Full Area Half Tone (TYPE=5) what does that look like for Yellow
          • mynameis
            • Jun 2015
            • 78
            Followed the procedure exactly.
            Checked contacts..seem fine.
            Tried 2 different dev units, same result.
            PG type 5 looks like 10-20% dens max, when sent with 255 value - barely visible.
            How would i check if the dev recieves toner? Tape the input hole and perform SPPLY-Y, then check if there's toner on the tape?
            • teckat
              • 16083
              u have any error codes in history ?
              does it look like toner is on Y DEV MAG ROLLER ?
              should be a rich yellow & not a washed out metallic look
              • mynameis
                • Jun 2015
                • 78
                Thanks Teckat.
                Programmed the DENS Values from the door, then made a few blank copies. Yellow went better and better..
                Now it's all up and running again.
                Seems like it was an air bubble in the toner transportation?!?
                • teckat
                  • 16083
                  Thanks Teckat.
                  interesting
                  always shake the toner or any toner bottle bottle before placing in printer
                  OEM
