Canon IR 2780 fax problems
  • Fearless V K
    • 620
    Test faxes sent from our office print OK. Several other sources print a few lines of the fax on each page, so that many more pages are printed than what should be. Has anyone seen this problem before. Just took over this machine. Drum was replaced right before we took it over (we didn't replace it, the last company did). Seem to recall a similar problem on another older Canon, something to do with resetting the drum counter?
    Don't take that toner with me!
  • alex@wocltd.com
    • 430
    1st turn OFF ecm for both tx & rx ,then try some of the following-
    Adjust service data #2 MENU Parameter No.07 between 0 and -15dBm.
    Note: It is suggested that the transmission level be set to 8 (dBm). Consult the
    relevant product manual for details of the default setting.
    • Echo measures
    Change the following bit switches of service data #1 SSSW SW03.
    Set Bit 4 = 1 to ignore the first DIS signal sent by the other fax machine.
    Set Bit 7 = 1 to transmit a tonal signal before sending a CED signal.
    Note: the default for SW03 bit switches 4 and 7 is 0.
    • Echo Protect Tone (EPT)
    Change service data #1 SSSW SW03.
    Set bit 1 = 1 to transmit an echo protect tone.
    Note: the default for bit 1 is 0.
    • Adjust NL equalizer
    Set service data #2 MENU Parameter No.05 to “ON”.
    Note: the default is off.
    • Reduce the transmission start speed
    Reduce the transmission speed by changing “TX START SPEED” setting.
    Note: It is suggested to reduce the TX start speed to 14400 bps in normal
    circumstances.
