Epson l386 ink pad reseter
  • Manoj ambatt
    • Oct 2019
    • 25
    Good morning friends
    I am facing problm with epson l 386 printer ink pad reset
    Try to downliad some adjpro but doesn't work
    Can any one suggest free rester? I am using win 7 64 bit
    Manoj
  • davel
    • Oct 2011
    • 1107
    • tsbservice
      Field tech
      • 8020
      Re: Epson l386 ink pad reseter
      You can use Maintenance Reset Utility once to enable print for short period.
      I never tried it, but here they claim free utility for that purpose:
      Resetting Epson printers waste ink pad counter using the SSC Service Utility ( The INK Store )
      • NexTan
        • Jun 2013
        • 10
        Maybe your download file was corrupted, turn off your antivirus while download and then get your adjustment program, its better specify usb number than autodetect, may useful, thank's.
        • ennerss
          • Oct 2021
          • 1
          Dude, just use any adjustment program for L388. You can check these Epson adjustment programs but I am not sure if there is any available for the L386 printer model. I recently used adjustment program for my Epson L120 from there.
          • NexTan
            • Jun 2013
            • 10
            Without using adjustment program, replace manually IC eeprom with new one.
