Epson 11880 Part identification
  • dmp1
    • Jun 2025
    Hi all,
    I was hoping someone could help me identify this part for my Epson Stylus Pro 11880. It is the part circled in the pic that is leaking cyan ink. It has a foil-like film over the back of it and has a small slit in it that is leaking cyan ink all over the floor. Thanks in advance!IMG_2433 2.JPG
    Re: Epson 11880 Part identification
    Originally posted by dmp1
    Hi all,
    I was hoping someone could help me identify this part for my Epson Stylus Pro 11880. It is the part circled in the pic that is leaking cyan ink. It has a foil-like film over the back of it and has a small slit in it that is leaking cyan ink all over the floor. Thanks in advance![ATTACH=CONFIG]47958[/ATTACH]
    even IF we identify the part for you , you cannot buy those parts because you aren't a trained tech for Epson. could be the ink tubes are leaking
    your best bet is to hire a trained tech because you have more than one problem with that machine.
    you need the manual to do adjustments.
    since you are an end user you can't provide the life counts on parts, and you can't just 'reset' the parts.. you must replace ..do adjustments in service mode.
    • NicolaiBL
      • Apr 2021
      • 3
      Hi there!
      As a trained Epson technician I would really recommend that you use on of us! It is not so, that you could'nt do this by your self. It seems like an easy fix!
      Now, I am not allowed to share any details with you, on this subject, other than hire a certified technician. Sent that picture to them, and you'll most likely have the mashine up and running in no time
