How to reset the administrator password on an EPSON WorkForce Pro WF-M5799dwf?
  • OoooO
    • Oct 2024
    • 3
    Long time lurker here
    Can anyone tell me how to remove the administrator password on an Epson WorkForce Pro WF-M5799dwf printer? I inherited nearly 100 locked devices. I had never worked with Epson devices before.​ No help from Google
  • Hart
    • Feb 2024
    • 425
    AFAIK you can't without replacing the Main Board.
    The default settings allows to make changes if you're in front of the copier, but if the "local" menu is also locked, you're fucked.
    • ATM
      • Apr 2025
      • 51
      You can use ADJ tool from Epson or use maintenance menu, but you will have to visit every single device to do that. ADJ tool is available only for authorised Epson service.
      • Blind Avocado
        • Jan 2021
        • 41
        If you can get to the settings menu, got to general settings, System administration, Reset, erase all data and settings. That should set the printer back to factory default including the admin password
        • usta
          • Oct 2013
          • 45
          Did you find a solution to your problem? ozmeniko@gmail.com
