Envelopes C1070
  • ullrich
    • Aug 2015
    • 2
    Envelopes C1070
    Any suggestions for getting envelopes to print correctly? We are getting a double image use the envelope fuser.
  • allan
    RTFM!!
    • 5462
    Re: Envelopes C1070
    The machine could be running too fast. Did you select the proper media type?
    Whatever
    • ullrich
      • Aug 2015
      • 2
      Re: Envelopes C1070
      The envelope fuser only has 4 paper weight settings and I have tried all of them.
      • lucky13
        • May 2008
        • 125
        Re: Envelopes C1070
        I have had this issue before
        for a workaround I had to lower the fuser temp 5-10 deg and rotate env 180 deg to print on end of env I believe there is a spring kit to put more pressure on fuser rollers. I see this when printing black on 20lb bond and envelops good luck
