minolta cspro ep 2010 problem
  • Green Rose
    Hi!
    I am new to this forum. I hope someone can help me out. I cannot get my copier back to work after I changed the toner. The maintenance light came ON (not flashing) and remains that way, preventing the Start button light from changing to green. I clean almost everything; I even try to refresh the toner, dehumify the drum... and the copier still does't work. Can somone help me find the solution? I much appreciate your help. Thanks you.
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    If the maintenance light is on solid then the maintenance counter needs reset in tech rep mode for the machine to function properly.
    • vintech
      Anyone know what the code C05 is on this machine?
      • lvangsnes
        Try meter count, stop, zero zero, stop, zero one.
        • cobiray
          • Mar 2008
          • 1199
          I think that's old enough to be the older sequence of stop, zero, stop one.
