BH C652 Doc feeder skew
  • Desert Rat
    • May 2008
    • 1089
    Looking through the book I saw there were only two mechanical adjustments.
    I should be able to do this, but...
    I was checking the height, the back was up and the front down. Adjust the screw CCW and I could
    feel with a single sheet of paper that it was coming down but I still had more pressure
    on the front. So I turned the left rear screw some more and did the same for the right rear screw
    and there was no real change. Turned the left rear screw some more and it came out. I put it back in.
    I must be missing some thing here. I adjusted the screw for skew on the right rear for the best copy but
    it is still skewed a few mm's out of spec.
    I am going back today or tomorrow to start over.
    I'm getting a handle on the hot calls that have been challenging me.
    So may be I can focus more on this one before it gets to hot.
    Also I'm getting some intermittent jams from the paper feed. I will need to get more
    info on this problem. The paper stops just before the trans fer roller. The other day
    I replaced the rear arm on the transfer roller. This helped a lot but did not completely solve
    the problem.
    Thanks for your help
    DR
    • 14815
    Re: BH C652 Doc feeder skew
    Have you run the service mode adjustments. Sometimes they will help.
    • Desert Rat
      • May 2008
      • 1089
      copier addict,
      Nope, but after glancing at them I can see that they may very well help.
      But how will it get the back left corner of the feeder closer to the glass?
      Or may be it doesn't have to be perfect just within a couple of .001 inches?
      I will see this machine again next week. I'll have a closer look at this problem.
      Thanks for bring that to my attention, sometimes I over look the obvious.
      I hate when I do that!
      DR
        • 14815
        Originally posted by Desert Rat
        copier addict,
        DR
        Make the DF as level as possible and then run the service mode adjustments. In the installation manual it explains how to level the DF.
        • Desert Rat
          • May 2008
          • 1089
          Good suggestion the install manual I will check to see if I have that one.
          Keep 'em coming
          DR
