magicolor bizhub c20 question
  • brent
    • Nov 2008
    • 1213
    this machine prints fine but the copies from the glass are not good.. so.. I try to take the glass off.. and I searched the book
    but I am too pissed off to really read I guess.. still am.. I mean really? so there are tabs and stuff
    what I am I missing.. is it supposed to be so hard to take the cover off to get the glass out?
    Or am I really starting to lose it? lol
    any advice would be cool I appreciate you guys
    brent
  • MVPunisher
    • 209
    Re: magicolor bizhub c20 question
    I know this doesnt sound like it makes sense. But clean the Printhead laser mirros good underneath the IUs. Not with the wand. Remove the IUs and clean them by hand.
    For some reason with these I have noticed that with a dirty laser the "prints" still look good, while copies look terrible. Leading you to believe it the optics when it really is not...just my experience.
    • allan
      RTFM!!
      • 5462
      Here is something i found. Looking at the parts manual there are a couple of screws? and weird looking tabs on the side. 2 on each side. Using a guitar pick helps to pry stuff apart.
      C 20 COPY QUALITY COUNTERMEASURE ISSUES
      WITH THE DOWN ARROW ,SCROLL DOWN TO UTILITY MODE
      PUSH SELECT AND SCROLL DOWN TO SCAN SETTINGS
      PUSH SELECT AND ENSURE THAT THE RESOLUTION IS ON 600X600 DPI
      UNDER THE UTILITY MENU SELECT COPY SETTING
      SELECT THE QUALITY PRORITY AND SELECT MIX
      THERE ARE OTHER OPTIONS LIKE TEXT/PHOTO, FINE/MIX, FINE/TEXT, FINE/PHOTO
      DEPENDING ON YOUR RESULTS ,THEY CAN BE SELECTED
      ENTER SERVICEMAN MODE ( SELECT STOP 0,0 STOP 0,1 )
      UNDER THE FUNCTION MENU ,SELECT FAX RES.COPY TEST
      THERE IS AN AN OPTION BETWEEN CCD,FAX AND ADF,FAX
      WE HAVE ADJUSTED BOTH DEPENDING ON WHERE COPIES ARE BEING MADE FROM
      SELECT CCD,FAX AND SELECT STD/TEXT
      PUSH SELECT AND UNDER THE QUALITY ( ORIGINAL ) MENU SELECT STD/PHOTO
      BOTH THE CCD.FAX AND ADF,FAX CAN BE ADJUSTED.
      IF THE SOLIDS ARE NOT SATISFACTORY:
      UNDER THE ADJUST MENU IN SERVICEMAN MODE
      THERE ARE OPTIONS TO SELECT MAXIMUM DENSITY FOR C,M,Y,K
      THER ARE OPTIONS LIKE IMAGE ADJUSTMENT FOR THICK 1, 2 ,ETC AND TRANSFER
      POWER. WE HAVE ADJUSTED OUR TRANSFER POWER TO +1 AND YELLOW DENSITY
      TO -1.DEPENDING ON WHAT THE CLIENTS NEEDS ARE.
      Whatever
      • allan
        RTFM!!
        • 5462
        The BH 161 is a prime example of that.
        Like the C35 stays nice and clean inside the optics cavity for a really long time. the C20 is sealed up well. You can look at the light path without removing the glass to look for cloudy mirrors.
        Whatever
        • Hansoon
          • Sep 2007
          • 3385
          Brent there might be a haze on the platen glass too. You have to remove the top cover since the platen glass is sealed into it. Remove the ADF, take out the 3 screws under the rubber covers at the underside of the control panel and remove it, remove several screws at the rear top of the top cover. As far as I remember there's also one screw hidden at or near the rear fan grille to be removed. Than you can take the top cover off. Sounds complicated but it isn't really. Careful with the mirror carriages cause they bend easily causing warped copies/scans.
          Did I tell you that I HATE this machine and especially when it doesn't recognize toner and drum cartridges?
          Hans
          • brent
            • Nov 2008
            • 1213
            hate this machine? yes I hear you haans. lol I will check the things you guys told me to on my visit out. next day or two
            hoping the machine will fall off the stand before I get there.... darn
            thank you guys
            brent
