Konica minolta c253 scan to email problem
  • mearmi
    • Oct 2010
    • 346
    [Misc] Konica minolta c253 scan to email problem
    Scanning function (scan to email) stops working randomly. Has to reboot the printer every time.
    Please advise.
    Thanks and Regards,
    Mearmi
  • rrrohan
    • Sep 2011
    • 1977
    Re: Konica minolta c253 scan to email problem
    Please advise.
    Thanks and Regards,
    Mearmi
    Scan fails or you mean it locks up the copier?
    • mearmi
      • Oct 2010
      • 346
      Thanks for your message
      scan fails
      copier and printer is working fine
      • rrrohan
        • Sep 2011
        • 1977
        If it works sometimes but not always its most likely a DNS issue. I would turn off IPv6 as I'd bet your not using it, this rules out IPv6 DNS issue.
        Adding your ISP DNS address into copier
        • mearmi
          • Oct 2010
          • 346
          Have Turned off IPV6 and checked/confirmed the DNS server address.
          1st scan goes fine and then start getting error "Failed to complete job ... check Log.
          Restart Printer and same error again after sending 1 scan.
          Please advise thanks
          • rrrohan
            • Sep 2011
            • 1977
            Is mail server in house or remote?
            Sent from my SM-G900I using Tapatalk
            • mearmi
              • Oct 2010
              • 346
              Remote
              • rrrohan
                • Sep 2011
                • 1977
                Try putting mail server as IP instead of host name. If that works its DNS, if it still doesn't reliable work its not a DNS issue
