hello everybody,
i've installed allredy 2-3 dozen of it, but unfortunately i discovered a problem in a 3 machines so far. It can be describe like a rattle from white gear (31) from toner supply that actuate with imaging unit
the problem is not only rattle, but over toning, a BIG toner mess and a error codes like C0070 and display message "1st side cover open" caused from switch under hopper Section
if someone was found a clear solution for this will be helpfull i just fix it but dont have clear idea to describe it if found will be post
anyway
wish U all the best and let the force be with you ...
anyway
