Bizhub C360 consumable life counter
  • jwagner
    • Aug 2025
    [Misc] Bizhub C360 consumable life counter
    We have replaced the imaging transfer belt, and drums, prior to them blowing the fuse, but the Counters do not reset. how do you go about resetting the counters, or are you better off just leaving them at 0?
    • 14932
    Re: Bizhub C360 consumable life counter
    The drum counters clear themselves, the transfer belt needs to be cleared manually. Go into service mode- counter- life- new release. Select transfer belt open the front door and press Start.
    They will show 0 when they are cleared.
    • allan
      RTFM!!
      • 5462
      Does the drum counters clear.
      Whatever
      • jwagner
        haven't checked yet - some of the other counters are not indicating an end of life date. wondering if last person didn't install the PPLM life stop firmware. if I check the firmware version, what am I looking for to see if it has been installed?
        thanks
        • allan
          RTFM!!
          • 5462
          What is Softswitch 51 on?
          Whatever
          • jwagner
            11110000
            • allan
              RTFM!!
              • 5462
              What is the hex value? F0? is should be 30.
              Whatever
                • 14932
                Originally posted by jwagner
                11110000
                This is the correct softswitch setting for PPLM. And switch 55 should be 00001100. And switch 50 should be 00000001
                Hex for switch 51 should F0
                • Mr Spock
                  Vulcan Inventor of Death
                  • Aug 2006
                  • 2064
                  thanks
                  Most machine will not show end of life until approx. 30% of life has been used.
                  • allan
                    RTFM!!
                    • 5462
                    Ok must be a regional thing.
                    Whatever
