Konica Minolta C253 Scan / Fax not available
  • Copyfix
    • Jul 2012
    • 8
    Hi,
    When I select the scan button it does not respond, I get a beep sound as if there is an error. I have tried trouble reset still the same.
    Is there a possibility the scan function have been disabled?
    Copyfix
  • mo0651
    • 1054
    Re: Konica Minolta C253 Scan / Fax not available
    Use the search feature here, That's been answered a lot! HDD uninstalled or failed.
      • 14815
      It is more likely the HDD is either not installed physically or electronically. Remove the rear right cover to see it it is installed physically. If it is there go into service mode and turn it on there.
      Hope this helps
      • emujo
        • Jun 2009
        • 3009
        Is there any kind of authentication enforced at the MFP? Can you access the user boxes? Emujo
        • peter42
          • Jan 2012
          • 110
          Box-Fax and Scanfunctions are disabled if HDD is not availiable.
          First check in Service mode, if HDD is present and OK.
          Check again in Service-mode, do a HDD format and if it goes OK, install Animated stuff as in Display requested.
          If not, Replace HDD, do a low level format, after that a high level format and install Animated stuff as in Display requested.
          Have an Iphone with lot of Music or some unreaded Servicemanuals with you, it takes some time, to complete that procedure.
          greetings peter
          • Copyfix
            • Jul 2012
            • 8
            Originally posted by Copyfix
            Hi,
            Copyfix
            Yes you where correct HDD was not enabled
            Thank you all
