After turning the main power and sub power switches on. The screen will flash the loading screen for a second then the display goes dark. The fans will turn on as well, but stop when the screen turns off.
One of the seals on the vertical pipes blew out, made a huge mess. The machines was running fine, until it starting leaking waste toner. I had to remove pretty much every component down to the frame to clean all of it up. I've looked over all the connections everything seems to be fine.
Just some additional info, a coworker of mine decided to put a magnet on the cover were the hard drive is. I don't know if it cleared it or now.
Any insight is greatly appreciated. This has been a hell of a project, I'd say at least 20 hours.
