konica 282 NTLM
  • DPSolutions
    • May 2015
    • 20
    konica 282 NTLM
    It possible to activate NTLM v1/v2 on konica 282?
  • emujo
    • Jun 2009
    • 3009
    Re: konica 282 NTLM
    Yes, KM released firmware for this several years ago...but you have to be careful, there are separate files depending on which phase MFP you have..
    Version PHASE_2_ONLY_G11-06 9/29/2009
    9/29/2009 19.53 MB 222 282 362 A11U-0100-G11-06-002.exe
    Release Notes: bizhub 222, 282, 362 PHASE 2 ONLY Special MFP Firmware Version G11-06
    CAUTION: You CANNOT upgrade Phase 1.0 machines to Phase 2.0 level firmware
    Phase 2 serial number cut in:
    From "A11W011002051" onward => bizhub 222 Phase2
    From "A11V011001338" onward => bizhub 282 Phase2
    From "A11U011001706" onward => bizhub 362 Phase2
    Serial numbers below are Phase 1 systems.
    Version PHASE_1_ONLY_G05-09 9/29/2009
    9/29/2009 11.25 MB 222 282 362 A11U-0100-G05-09-002.exe
    Release Notes: bizhub 222, 282, 362 PHASE 1 ONLY Special MFP Firmware Version G05-09
    The firmware listing are not links...You are on your own to get the files...Emujo
    • DPSolutions
      • May 2015
      • 20
      Re: konica 282 NTLM
      My MFP is a phase 2.
      I upgraded the firmware. Where can I find the new option to be activated? In the Web portal I can not find it.
      • DPSolutions
        • May 2015
        • 20
        Re: konica 282 NTLM
        There is a soft switches to edit maybe?
        • emujo
          • Jun 2009
          • 3009
          Re: konica 282 NTLM
          NTLM 1/2 is added with this firmware, no switches to set. Maybe you have another issue. Emujo
