C451 image problem
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    C451 image problem
    Seems to happen first thing in morning and clear itself up after 15 or so pages0908151321.jpg
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
  • allan
    RTFM!!
    • 5462
    Re: C451 image problem
    There was a mod for the K iu to keep it in place correctly. If you reseat the IU before printing in the morning it would prove just that.
    Whatever
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      The IU in it was replaced not long ago for same issue so I'll look into that. Thanx
      • Kidaver
        Ghoulscout
        • Apr 2011
        • 912
        Also anyone know what special FW version is needed to turn off end of life message? I replaced the fuser with a refurb one KM sent but it never reset.
        • allan
          RTFM!!
          • 5462
          Goto service mode then counter then life. look for "new release" on top open the front door touch fuser then start button. No firmware required for fuser and transfer belt.
          Whatever
          • habik
            • 2013
            You meant probably C452.
            C451 needs the firmware to enable SSW 51 and 55 to change HEX positions.
            Gp1 should be the one
            Firmwares HERE
            • Synaux
              • Mar 2012
              • 1224
              If this is the infamous developer spew due to poor HV contact (as mentioned, there is the metal mod, or wedge a wad of paper or something between the blue IU latch and the IU) beware that the dev with get on the yellow IU (and if its real bad into the other IUs and transfer belt).
              I would try to not run it until you have the issue sorted out.
              This issue was fixed with the c552/c652s.
              For the IU message you also need to go to service mode and immediately press stop 0 c and change the IU stop setting in conjunction with the SPECIAL FW and switches already mentioned.
              • Synaux
                • Mar 2012
                • 1224
                Here are some bulletins
                7370.pdfdlbt1002269en00.pdf
                • allan
                  RTFM!!
                  • 5462
                  sorry my bad.
                  Whatever
                  • bachirabouzeid
                    • Sep 2015
                    • 17
                    The problem is on black and color copies?
                    try to clean the metal behind the transfer roller, and ther is a spring on the left side of the transfer increas his tension and also clean it well
