Anyone had any luck with Single Sign On and the KM Print Driver???
Authentication is on/External Server. AD is working for walk up users...Copy/Scan works as expected.. Under network Settings SSO is enabled and we have joined the MFP to the domain. Print Driver has SSO enabled and under authentication/account track, SSO is checked. Normal fields for user name password are greyed out and I can see the logged in users name so I know the driver is pulling the correct credentials, but every print job immediately returns a authentication failed message. MFP log shows nothing has been sent, not even a deleted due to log in error. Turn off SSO and manually put the credentials in and MFP prints as expected. MFP is at K2, function version 7, driver is 5.X.X.X. have also tried the universal driver, but it looks like SSO isn't supported. This particular MFP is a C754e, but we get the same symptoms on a 2 other 3 series MFPs. No failure message when getting device information so I know the MFP info is being communicated back to the driver. Any ideas? TIA Emujo
