Bizhub C450 - Forward Tx error / Login error
You need to have the latest firmware level or it will not authenticate to a windows 2003 domain. Bring the unit to phase 2 and above. -
rydmec
Give this solution a chance.
Change the default domain security settings.
Open Server Managemant:
Default Domain Controller Policy -> Security Settings -> Local Policies -> Security Options
Change:
Mircosoft network server: Digitally sign communications (always) to "disabled"
Microsoft network server: Digitally sign communications (if client agrees) to "disabled"Comment
rydmec
Thanks Dallas, but before I give that a try I like to know if there is anything that can be done either at the C450 or at the destination workstation first. The only reason for this is I don't have much freedom to play with any of the security settings. This network deals with a LOT of medical records & other confidential material.Comment
In the wins configuration put the address of your server even if you are not running wins on the server. If this doesn't work then use the KonicaMinolta FTP utility works great every time.
Also when setting up scan to PC SMB if possible always use the administrator name and password.Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI BoxesComment
