c250 error c5357
  • Gab
    • Aug 2015
    • 671
    c250 error c5357
    This error code appeared after i removed machine to an other place. When warming finish if i open and close front door machine works with no problem. Service manual says it is cooling fan but i checked fans and they look that they work fine. Also replaced the fans at power supply and the fan at the upper rear side (the left one) with no result.Any idea?
  • freixi
    • May 2009
    • 53
    Re: c250 error c5357
    Hi,
    make a trouble Reset
    turn machine off and then turn back on while holding down the utility/counter button after a while a trouble reset box will appear on the screen press on the box and then restart the machine.
    Good luck
    Freixi
    • laitang
      • Nov 2012
      • 627
      Check item [8] Cooling Fan Motor/1 (M12)
      • Gab
        • Aug 2015
        • 671
        Originally posted by laitang
        [ATTACH=CONFIG]30638[/ATTACH]
        If cooling fan is this fan in front of power supply i already have replaced it with one from an other
        copier, with no result.
        Can it be something else?
