PC-410 Tray Problem
  • splblazer91
    • Jul 2014
    • 204
    PC-410 Tray Problem
    Customer keeps getting a message to load the paper but it was loaded. Left side was full but wasnt moving over. It makes a popping noise and then throws an error. Take out half the paper and it works fine. So i went back to our office and tried it on our Demo Machine and it did the exact same thing. Any ideas before I tear into this thing tomorrow. Its gotta be a belt or gear slipping right?
  • Phrag
    • Oct 2012
    • 417
    Re: PC-410 Tray Problem
    So a full stack on the left side throws 0214, but half a stack works fine?
    And you brought the faulty PC unit back to your office and it did the same thing?
    • splblazer91
      • Jul 2014
      • 204
      No. I didnt put their tray in ours. I just loaded our tray to the max line and it errored out and wouldnt move. It made a popping noise too.
      • allan
        RTFM!!
        • 5462
        Don't know about the shifting, but know about the lifting. A gear starts turning on the shaft. The flat spot on the gear strips.
        If you take of the front cover from the PC-410 you would see a drive. The gear i am referring to is the big one that drives the shaft that coils the cable.
        Whatever
        • CompyTech
          Super Tech
          • Feb 2011
          • 706
          Always had this problem on the PC408.. So sounds like the 410 has the same design. Great, now I know to look out for it.
