KONICA BIZ HUB 754
  • antone
    • Oct 2014
    • 344
    KONICA BIZ HUB 754
    Installation of FK 511 fax unit...phone line good..dials number before documents get pulled in!
    • 14723
    Re: KONICA BIZ HUB 754
    Did you get the Marketing Area set correctly?
    • antone
      • Oct 2014
      • 344
      Yes and target area
      • SmellsHot
        Head Tech
        • 512
        Disable fax option from service. Power cycle. Then re set fax option back up. This usually takes care of any weird faxing issues
        Everyone has the right to be stupid. Some people just abuse this privelage more than others
        • darry1322
          • Oct 2010
          • 817
          Can't remember the exact wording, but it sounds like "Memory TX" is turned off. Memory TX stores the doc in memory before trying to send the fax. With Memory TX turned off, the machine doesn't store the job in memory. It connects to the other fax first, then sends after establishing a good connection. Memory TX off is more secure since the doc is never stored on the machine.
