[Help] Problem Bizhub 652 b/n
  • CopiersHouse
    • Feb 2015
    • 5
    Hello, Well I'm a technician and this oportunidada me out a mistake that I still have a Bizhub 652 B / N
    First mistake : comes out as a red line around the panel.
    Second mistake : I print a copy test and I get all lines in copy and print .
    To review ?: Review the cylinder , strip , Laser, loose connectors (There was nothing all good) and no clean plates also look good panel and all is well
    Apparently it is an update of the go
    I hope I can clarify my doubts.
  • marvin_PL
    • Jun 2012
    • 24
    Re: [Help] Problem Bizhub 652 b/n
    Hi,
    I had similar problem i c353. i think mfp board needs to be replaced (this with memory)
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      yep, corruption of the image processing memory - unfortunately the chips that are soldered to the MFP board.
      • CopiersHouse
        • Feb 2015
        • 5
        If I upgrade the firmware will be possible to fix it?
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          No.
          In my experience MFP board replacement has been required on every single instance of this defect.
