So I have a C6501 that is having some color registration problems. It is a little weird as the shadow around the text is more like dotted lines rather than solid. This machine is in my office, I have a C6500 also in my office to swap parts from.
I have swapped - All drums and Coronas, Transfer Belts assy, Fuser Assy, Color reg assy, Fiery. I have ran recall standard data, belt line speed adjustments, auto gama, color reg etc.
In the example if you take a look at the word "Dustin Moffitt" you will see the top one is from the problem c6501 and the bottom one is from the c6500.
My next thoughts were lasers and image processing board just seeing if anyone had a suggestion. Thanks
