Konica Minolta C350
  • Vesigoth
    • Mar 2008
    • 133
    Konica Minolta C350
    Is there a way to set the default color to black on this machine. I got this machine in a trade in and I'd like for the prints to come out in black without having to tell the machine all the time. Can this be done from Admin. setting or tech rep mode? I've not been able to find it in either mode. Thanks for any help.
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    It's in the admin mode. I don't recall where exactly but you can download the operation manuals at KONICA MINOLTA USA
    • bgbas
      • Feb 2007
      • 60
      First set the copier to the defaults you want then touch utility/counter, user setting, initial setting, current setting, OK. I'm doing this from memory so it may not be exact, but should get you into the general area.
      • Nazakat
        • 67
        C350
        Imaging unit of Bizhub C350 can be used in bizhub C-250?????
        • Luther
          • May 2006
          • 682
          nope they can not
          • knpgazem
            • Jul 2008
            • 35
            this is the correct sequence of instructions. but this is for COPYING only, you will need to change the PRINTING defaults (at the PC) if you want all PRINTING to be greyscale also. otherwise there is a use the BZ250 PCL driver to prevent colour printing altogether.
