bizhub 421 error code c-5302
  • reli
    • Oct 2014
    • 6
    [Error Code] bizhub 421 error code c-5302
    Hello techs. need help error code c-5302, bizhub 421.
    Fan problem FM9. Already change it. PRCB change also. Any suggection.. This load check the fan are turning..
  • allan
    RTFM!!
    • 5462
    Re: bizhub 421 error code c-5302
    Did you make sure its the right fan "exhaust fan"?
    Did you change it with the correct part?
    Does the fan power up?
    Or is there and DC voltage for the fan?
    Do a trouble reset for the fun of it.
    Whatever
    • reli
      • Oct 2014
      • 6
      thanck you for your reply, yes I change all the unit. came with two fan
