C280
  • CrapAimer
    • 296
    C280
    Hi All
    Was trying to copy over the address book from a C280 to a C220 came up with product name different is there a way around this ??
    George
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: C280
    data administrator will absolutely do it, not sure how you are trying to do it.
    Data Administrator - PageScope Utilities - Solution Software | KONICA MINOLTA
    • mo0651
      • 1054
      Re: C280
      Have had success with opening the abbreviated text file with note pad...then editing the model number in upper left corner. This has worked on C203 to c253 and BH223's.
      • CrapAimer
        • 296
        Re: C280
        Thanks for the info done as you said opened it up changed the file name and hey presto it worked a treat
        Many thanks
        George
        • wseyller
          • Sep 2012
          • 1129
          Re: C280
          That doesn't work on newer models. I use data administrator which works between most bizhubs.
          Sent from my XT1254 using Tapatalk
          • JR2ALTA
            • Feb 2010
            • 2033
            Re: C280
            Always double check SMB scans after transferring with Data Administrator. The encrypted password is often HIT OR MISS. Sometimes just transferring again will fix it.
            • wseyller
              • Sep 2012
              • 1129
              Re: C280
              I've always assumed with data administrator that password don't carry over. It had never for me anyway.
