Konica Minolta C220, 280 toner near end message
  • Alex1
    • Oct 2012
    • 285
    I need help with going into service mode and disable the near life and toner near empty message display settings.
    how do I locate the settings please
  • allan
    RTFM!!
    • 5462
    Re: Konica Minolta C220, 280 toner near end message
    Service mode -> system2 -> unit change.
    If you initialize the engine data the toner levels will all show full.
    Whatever
    • Alex1
      • Oct 2012
      • 285
      Thanks for that. How do you initialize engine data??
      • splblazer91
        • Jul 2014
        • 204
        I think he is just warning you. You dont want to initialize the engine data if you dont have to.
        • Alex1
          • Oct 2012
          • 285
          I went into service mode as explained in the previous message I turned off toner low warning and the cyan still shows low. So I might have to initialize engine
          • Hansoon
            • Sep 2007
            • 3389
            http://www.copytechnet.com/forums/ko...indicator.html
            Hans
            • Alex1
              • Oct 2012
              • 285
              I appreciate the link you sent but I still don't know how to initialize the engine or manually feed toner in service. Can you please help
              • Hansoon
                • Sep 2007
                • 3389
                You have a PM. Cannot post the Service Mode procedure here in the open.
                Hans
                  • 14812
                  Where is the toner showing low? Do you mean there is an actual message say replace toner. Or are you talking about the bar graph that shows toner level?
                  • Alex1
                    • Oct 2012
                    • 285
                    The bar graph shows low, once you install new toner it keeps showing low on the bar graph
                      • 14812
                      You have to wait until the machine tells you to replace toner on this model. Just live with it. It isn't hurting the machine when it displays low toner on the bar graph. Next time wait until there is a message telling you to replace toner.
                      • allan
                        RTFM!!
                        • 5462
                        I you really really want to you can strip and vacuum the hopper.
                        If you initialize the engine data you need to redo gradation adj.
                        Whatever
