Magicolor 2400w
  • eliaso
    • Jul 2014
    • 52
    Magicolor 2400w
    Magicolor 2400w top margin off
    ...paper jam at transfer roller" error message, even though the paper came out empty without jamming.
    This only have I found:
    God created mankind upright,
    but they have gone in search of many schemes.
    • 14972
    Re: Magicolor 2400w
    I'm no expert but, if the paper is exiting and the machine thinks it isn't exiting the problem is likely a sensor.
    • eliaso
      • Jul 2014
      • 52
      Re: Magicolor 2400w
      the paper turns out with a shadow of half of the copy , the copy stays on the belt and ''jam paper'' appears on the screen
      • Hansoon
        • Sep 2007
        • 3391
        Re: Magicolor 2400w
        Sticky patch on solenoid(s)
        Hans
        • eliaso
          • Jul 2014
          • 52
          Re: Magicolor 2400w
          Hi
          I replace the pad in this solinoid it make about 10 copies then it flash the error service call 14
          • Hansoon
            • Sep 2007
            • 3391
            Re: Magicolor 2400w
            Solenoid and/or clutch of the 2nd transfer roller. You'll find that solenoid just above the other one hidden in the frame under the stepper motor visible in the picture. I'll bet also in this case its a sticky patch but I had also several times that the grease in the clutch became gooied up. WD40 is your best friend with that. Leave the clutch in the machine, just put the straw of the WD40 on the tiny opening on the sleeve of the clutch where the spring coil peeps out and soak with WD40, wiggling at the same time the sleeve to allow WD40 to creep into the spring. Your machine will run another two years or so at least.......
            Hans
            • eliaso
              • Jul 2014
              • 52
              Re: Magicolor 2400w
              Hi
              yes I change the pad for the solenoid of the transfer belt ,it work good .
              thanks
