IP601 firmware installation
  • bajetrini
    • Jan 2008
    • 23
    Hi I managed to get the IP601 Print controller firmware loaded to the printer and booted up the printer and it through out the IP page and shows ready to print but when I send a test page to it the printer just throws out garbage rather than the windows test page.
    Any ideas on what to do next anyone????
    thanks
    Bajetrini
  • RockETop
    Curmudgeon at large
    • Apr 2007
    • 171
    thanks
    Bajetrini
    Try a different printer driver. PS if you currently have PCL, or PCL if you currently have the PS driver.
    • bajetrini
      • Jan 2008
      • 23
      Where do I get the drivers from? Do you have them you can send for me?
      Not sure what I am using a PS or PCL
      thanks
      Mike
      If you have you can email me at miker@caribsurf.com
      • montana
        • Aug 2008
        • 392
        hi.i guess something wrong with cable.check the cables.
        i wish you good luck
        • Haroldbfix
          • 212
          thanks
          Bajetrini
          I agree sounds like a driver issue, try a pcl driver. The controller may not have the postscript option there for if you use a ps driver it will cause garbage to print, because the controller cant interpret ps info without the option enabled on the controller.
          • RockETop
            Curmudgeon at large
            • Apr 2007
            • 171
            thanks
            Mike
            KONICA MINOLTA Global
