Biz Hub 645e
  • antone
    • Oct 2014
    • 344
    Biz Hub 645e
    Jams 72...22 one copy exits..than stops
  • splblazer91
    • Jul 2014
    • 204
    Re: Biz Hub 645e
    Small finisher or the big one?
    • antone
      • Oct 2014
      • 344
      Re: Biz Hub 645e
      FS 534
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Re: Biz Hub 645e
        check the black finger in the middle of the exit hasnt flipped forward.
        If i had a dollar for each time I have fixed this - i wouldnt be doing this crap for a living anymore.
        • splblazer91
          • Jul 2014
          • 204
          Re: Biz Hub 645e
          If i remember correctly that is a jam coming out of the top finisher tray. I usually fix it by tightening the tension on the top cover. There is a spring you can stretch that holds the cover tighter when closed. Also, there are black springs on the idler rollers on that cover. Cut them and make them tighter as well.
          • darry1322
            • Oct 2010
            • 817
            Re: Biz Hub 645e
            I just had one of these last week.
