Got a c6500 that's constantly calibrating - we're talking every couple of hundred sheets sometimes. I've tried adjusting some of the dipswitches on bit #23 but can't seem to limit it. I've PM'd and also ran the recommended initial setup procedure, but nothing seems to be helping. It's also going through toner like nothing else, produces a ton of waste toner!
2nd problem is the trailing edge smudging on heavier stock - always around 8-10mm from back edge. I don't know if there's some judder before it hits the fuser causing the toner to unsettle.
Does anyone know of any fixes for this?
Thanks.
Thanks.
