Part number needed BH 751
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1250
    The stapler unit for the FS-524 sorter (staple unit part# 15JK R706 00) has a small black plastic flag that engages the microswitches when the staple ctg. is installed. Customers break them or remove them. Does anyone have a part number or a source for that flag assembly?
  • allan
    RTFM!!
    • 5462
    Re: Part number needed BH 751
    I don't think the staple units or the staples are made by KM.
    Whatever
    • 907tec
      • 434
      Not sure if it's the same part, but the same piece you are describing is [Actuator - 15SJ P720 00] in the C451/FS608 manual. I have used that same actuator in several other machines as well, so I wouldn't be surprised if it fit the BH751/FS524 as well.
      • blazebusiness
        • 1250
        I'll order one and see if it works................thanks
        • blazebusiness
          • 1250
          Your part number helped us to cross reference that part:
          "15SJP72000 - Actuator for FS-602 FS-604 FS-607 FS-608 FS-610 FS-611 FS-612"
          Thanks again for taking the time to reply......much appreciated!
