C280 EK-605
    • 14522
    C280 EK-605
    We just got a previously owned C280 that is equipped with an EK-605 which is supposed to support bluetooth. I know nothing about these so I'm hoping someone can help. We are just going to re-sell this machine so it really is not important, but I am just interested in how it works.
    I went through the installation instructions and made sure everything was enabled, but I can't get bluetooth to work. It shows up in Pagescope as a Local Interface.
    Does this option allow bluetooth printing?
    Does anyone have information about these.
  • Motormount
    • Sep 2010
    • 78
    Re: C280 EK-605
    I had the same thing: lease return with Bluetooth I just had to figure out. It's not easy, or worth the trouble. If you have all the settings enabled, this should help. This is from the
    12.7.2 Printing a document
    Reference
    - To print from a cellular phone or PDA, set [Administrator Settings] −[System Connection] − [Cellular
    Phone/PDA Setting] to [Allow] in advance. For details, refer to page13-59. To use a Bluetooth communication,
    [Bluetooth Setting] must be enabled in this machine. For details, referto the [User's Guide Network
    Administrator].
    - When [User Authentication] is specified on this machine, even aregistered user cannot print a document
    unless printing from a cellular phone or PDA is allowed in the machinesetting. For user authentication,
    contact the administrator of the machine.
    - For details on the User Box functions of the machine, refer to the[User's Guide Box Operations].
    - For the operation of a cellular phone or PDA, refer to the operationmanual of the cellular phone or PDA.
    1 Set the cellular phone or PDA to enable Bluetooth communication.
    2 Press the User Box key on the control panel.
    % Press [User Box] when the application menu is displayed.
    Communication protocol Bluetooth Ver. 2.0 + EDR
    Supporting profile OPP/BPP/SPP
    Supporting file type PDF/Compact PDF/XPS/Compact XPS/TIFF/JPEG/XHTML/Repli-
    Go
    of UTF-8/Shift-JIS/ISO-8859 and the link file extensions of
    JPEG/JPG/PNG.
    PIN code 4-digit number
    bizhub C360/C280/C220 12-30
    12.7 Printing from a cellular phone or PDA 12
    3 Select [Mobile/PDA] in [System User Box], and press [Use/File].
    4 Press [Print List].
    % To save data in a User Box, press [Save in User Box], and select thedesired User Box.
    5 Check the displayed PIN code.
    6 Select this machine in the cellular phone or PDA.
    % Select the data you want to send if it is selectable.
    7 Enter the 4-digit PIN code into the cellular phone or PDA.
    % You can check the print setting in [Check Print Settings].
    Once the PIN code is verified, connection is established and datatransmission and printing start.
    bizhub C360/C280/C220 12-31
    Reference
    You can configure print settings from the cellular phone or PDA in[User Setting] − [Cellular Phone/PDA Setting]
    − [Print]. For details, refer to page 13-37.
      • 14522
      Re: C280 EK-605
      Thanks for the great info Motormount. It worked like a charm. Much appreciated.
