Konica Minolta Bizhub 211 dirty page
  • Orion2010
    • Jun 2015
    • 176
    hello to all,
    i have konica minolta bizhub 211, i change drum, blade , developer (DV 110) but if i copy i have stain in page 02.jpg01.jpg any idea ?
    thanks
  • keegan@kmzn.co.za
    • Nov 2015
    • 5
    Re: Konica Minolta Bizhub 211 dirty page
    Good afternoon
    few questions did you run TCR sensor adjust after changing parts and when you changed did you replace the whole unit or just drum / dev
    and have you tried changing transfer roller as well normally the problem would persist if the unit has not been replaced or TCR sensor adjust has not been run
    one thing to also look at the first image is not to clear but it also looks like there are marks being left from fuser.
    • allan
      RTFM!!
      • 5462
      Did you vacuum out the cleaning unit?
      Did you clear the life counters.
      Did you do ATDC?
      Whatever
      • Don N.
        • Nov 2011
        • 409
        Very hard to see, but fuser?
        Sent from my Nexus 5 using Tapatalk
          • 14972
          You said it happens when you "copy". Does it also happen when you print?
          • Orion2010
            • Jun 2015
            • 176
            yes in print and copy
