Re: 99-01 Controler jam??
I have had this on a C654e,I replaced the PRCB board,problem solved.This error will drive you around in circles because the service manual does not give you any info about revelant parts.I just happened to order that PRCB for the first time 2 or 3 years ago and another tech called me almost a year ago,he had the 99-01 code on a C654e,he ordered the board,I went out and put it in,fixed it.Tomorrow morning I am going to a C754e with 99-01,if you power down then back up,it will say warming up,then a couple of minutes later,BAM,99-01.And that is just letting the machine do its normal boot process,it wont go to ready after that time passes.Try removing the finisher first,reboot the machine,see what happens.The PRCB is probably the culprit.
NOTE:FOLLOW THE PRINTER CONTROL BOARD INSTRUCTIONS BY THE BOOK.
Hope this helps.
Hope this helps.
