Konica Minolta C8000 failure color registration. Help me!!!!!!!!!
  • tulintron
    • Jul 2014
    • 668
    Good afternoon sirs.
    I am technician in Brazil and answering some C8000. I have a problem, I need help.
    Equipment worked perfect before the review. After, it has failed in the color registration.
    But when the setting is performed, concludes ok.
    But the colors do not fit on the bottom of the paper.
    I will attach a bitmap 02 test patterns, # 80 and # 96.
    Color registration - ok
    Belt line speed - ok
    CD-Mag. Skew - ok
    Skew Init. Posit. Mem. - ok
    Beam Pitch - ok
    Moire Adjust. - ok
    Reversal of color lasers - ok
    Any hint will be bienvenue.
  • tulintron
    • Jul 2014
    • 668
    Re: Konica Minolta C8000 failure color registration. Help me!!!!!!!!!
    Discover the defect !!
    The Belt Transfer slipped as a whole, causing delay in the main transfer.
    After disassemble and clean the whole set, defect disappeared.
    I thank everyone who read this post.
    • allan
      RTFM!!
      • 5462
      Hi hope this helps.
      Whatever
      • t-rex
        • Nov 2008
        • 13
        CD-Mag. Skew - ok
        Beam Pitch - ok
        Moire Adjust. - ok
        Thanks[ATTACH=CONFIG]31369[/ATTACH]
        Hi, did you solved your problem?
        • Hansoon
          • Sep 2007
          • 3391
