Konica Minolta C3100p wrinkling paper
  • progoffice
    • Nov 2008
    • 336
    I would say that a majority of our c3100p machines in the field are wrinkling paper. This is regardless of up to date firmware, paper tray guide mods etc. Konica says this is not a widespread issue; however, their mods and firmware documentation contradict this.
    Is anybody else experiencing this wrinkle issue on these machines?
  • copyrooks
    • Oct 2013
    • 210
    Re: Konica Minolta C3100p wrinkling paper
    In my experience most of the desktop color products have this symptom. For instance the bizhub c35, c3350, c3100, c3110 i have seen this problem happen. In the past times i've called tech support about it they always tell me the fusing unit probably has something causing it. Even brand new machines out of the box have this problem sometimes.
    • HoonBoy
      • May 2011
      • 130
      The fusingunit for this printer as for the C3110 and C3850 series ar modified for this problem. There is an uneven pressure in fuser. Other (more thick) paper usually does not have this problem...
      • progoffice
        • Nov 2008
        • 336
        I'm not sure if the fusers have been modified or not. I just know we are still having this issue on several printers - even after replacing the fuser units...
        • andyf424
          • Jun 2013
          • 126
          I've got tons of these out in the field, sales guys love selling them. It's always a wrinkle toward the bottom of the page running the long way, usually 1/3rd to 1/2 up the page. Sometimes fusers fix, sometimes it gets worse. If anybody has come up with a solution, I'm dying to hear it.
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            There was a bulletin(#9677) out a few months ago that addressed this issue via firmware and a kit.. Looks like bunch of spacers and cushions for the tray.
            • srvctec
              Former KM Senior Tech
              • Oct 2009
              • 827
              The one time I had this problem on a C35, tried every possible fix suggested by KM, NONE of which worked. Brought machine in to shop and completely tore it apart. Noticed frame where fuser mounts was high (or low) on one side vs. the other and manually bent it straight, put it back together and machine hasn't made a wrinkled copy/print since. Give this a try.
              Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
              • andyf424
                • Jun 2013
                • 126
                Well, I try to keep all my machines up to date on F/W, I'll look into the spacer kit and check my fuser mounting also.
                • progoffice
                  • Nov 2008
                  • 336
                  Konica just came out with new registration springs to address the wrinkle. the part number for the new springs is A6DR702701. I have done a few and it seems to work. Took me about 3 hours on the first 1. Be careful when removing the gear pack cover, the gears are timed with the 2nd transfer roller and may fall out. The manual shows the timing placement of the gears. I had one that had no timing marks on the gear. Trial and error finally got it timed.
                  • spree
                    • Jun 2012
                    • 211
                    Hello everybody, I have this machine (KM C3100p) from customer - wrinkling paper. Try to buy new fixing unit - nothing happened. Try to buy new spring (A6DR702701) and next days I will try to change it. When you have any ideas, give it please here. Where starts to dissasembly the machine (what section to find in service manual). Because this spring I can not find in parts list catalogue (A6DR702701).
                      four year dead thread ..start your own with ALL info in OP
                      • progoffice
                        • Nov 2008
                        • 336
                        Pages from C3100P Solutions.pdf
                        Here's the bulletin that references the spring and how it's supposed to address this issue. It's been awhile since we've messed with these and have since moved on to different makes and models.
                        • byronf
                          Senior Member
                          • Sep 2017
                          • 109
                          Hi Guys,
                          Is this wrinkle ( Dent / curl) on the trailing edge?
                          Replace the highlighted below.
                          • spree
                            • Jun 2012
                            • 211
                            Originally posted by progoffice
                            [ATTACH]47185[/ATTACH]
                            Bad news guys. I changed spring A6DR702701 and still wrinkling paper
                            The original spring was red color, and new spring was red color, too. I think there was a good spring.
                            Now I try to change parts from "byronf" answer. But I must to order it.
                            That i saw at the machine, problem is at the exit roller - there the paper is twist a little at one side.
                            • spree
                              • Jun 2012
                              • 211
                              As "byronf" said, problem is at the exit roller, because the rollers opossite are not fiting to the exit rollers. The exit roller is faulty (maybe old material at the time).
                              Have anybody newer parts number?
                              Old one is not available in Minolta. Old one part number:
                              A0VD890102 - Paper exit Roller
