Konica 7130 Admin Password Reset
  • afgeraci
    Hi all,
    I just bought a 7130 off of eBay not too long ago and it works great. However, the person told me they forgot the admin password and had no idea how to reset it. As you probably know, without it, the network functions are useless (and may explain why i got a great price on it)
    To make a long story short, how to i reset the admin password?
  • smiley
    • Aug 2008
    • 616
    hello.....
    power off the machine then hold the 25 then switch on while holding both 2 and 5 then go to password setting. then all the password changs them to 000. change the key operrator to 0000 and also the e.k.c and and weeklly timer password....
    there is no glory without sacrifice
    • tmphelp
      hello
      if you want to alter the IP address e.t.c.
      you need the password for the network functions
      which is: sysadm
      • RRodgers
        • Jun 2009
        • 1947
        Originally posted by tmphelp
        hello
        which is: sysadm
        What his said.
        • montana
          • Aug 2008
          • 393
          [6] Password Setting
          This function sets the password to enter each mode.
          In the 25 mode menu screen, select the [5. Password
          setting], then the password setting menu screen will
          appear.
          Select the password to be adjusted/entered in this screen.
          Password setting menu
          1. Key operator password set
          2. E.K.C. master key code set
          3. Weekly timer master key set
          1. Setting key operator password
          This function sets the password to enter the key
          operator mode.
          Step
          1
          2
          3
          4
          5
          6
          Operation procedure
          Enter the 25 mode.
          [25 mode menu screen]
          Press the [5. Password setting] key.
          [Password setting menu screen]
          Press the [1. Key operator password set] key.
          [Key Operator Password Setting Screen]
          Enter 4-digit new password from the numeric
          keys.
          Press the [SET] key to set the password that has
          been entered.
          Press the [RETURN] key to return to the
          password setting menu screen.
          Note: When pressing the [RETURN] key without
          pressing the [SET] key, the setting is
          complete. However the new password will
          not be entered and the password setting
          menu screen will return.
          Reference: When setting a password to โ€œ0000โ€,
          the key operator mode can be used
          without a password.
