Network Settings on C350
  • glenbennett
    • May 2015
    • 68
    Good Afternoon,
    I am installing a bizhub C350 with the IC-401 fiery. I plug the machine into my customers network and I cannot find it on the network I figured out how to print the nic card and it gives me a completely different IP then on the network. How can I input the new IP, Sub & Gateway into the machine? I cannot get into or find any network settings on the machine? is it because of the installed fiery?
    Thank You
    Glen Bennett
    Thank You,
    Glen Bennett
  • matthewr88
    • Jul 2015
    • 28
    Re: Network Settings on C350
    been a while since ive worked on these but as memory serves me
    the fiery is your network interface, you need to connect the copier to the fiery
    1394 cable i believe the fiery is accessible via its webpage from there you can change ip address etc
    Can you fix it........we can fix anything its just how many parts do u wanna pay for
    • allan
      RTFM!!
      • 5462
      oops. ok make sure the controller is set. If so unset it and forget about the fiery. if you dont need it don't use it.
      Whatever
      • glenbennett
        • May 2015
        • 68
        I do not need the fiery, I unplugged the ethernet and put it in the pint control and still could not find network settings on the lcd panel. Can you please direct me how to get to network settings on LCD
        Thank You,
        Glen Bennett
        • subaro
          • Oct 2010
          • 1274
          From touch panel.
          utility > admin mode > administration code > network setting > common settings > tcp/ip
          think administration code is 0000 [ konica techs confirm please ]
