Bizhub 363 with FK508, cassette settings.
  • Hansoon
    • Sep 2007
    • 3402
    Bizhub 363 equipped with FK508, cannot find the settings / soft switches to force the machine to use a specific cassette for the incoming faxes. At the moment they are being printed out from cassette #2. The customer needs them to be printed from cassette #3, the LCC PC-409.
    Any ideas please?
    Hans
  • allan
    RTFM!!
    • 5462
    Re: Bizhub 363 with FK508, cassette settings.
    Ok, its a bitch to find.
    Admin settings-> Fax settings -> TX/RX settings -> Goto page 2 of 3 ->tray selection for RX print.
    Just scroll up down for the paper tray you want.
    Whatever
    • emujo
      • Jun 2009
      • 3009
      User setings/printer settings/report settings might work also...just choose the tray you need here. Emujo
      • Hansoon
        • Sep 2007
        • 3402
        Thanks guys.
        Hans
        • Hansoon
          • Sep 2007
          • 3402
          Did as advised but machine keeps using the #1 Cassette. edited: for the TX-Report, normal faxes are using the desired cassette. Played with all settings but it still takes A3 size paper from the upper cassette though settings say to use #3 which is the LCC. No way to use the manual feed port too - which would have been an alternative for the customer, cause one can choose only cassette #1,2,3.
          Had no time anymore yesterday to find out but could it be that it needs paper with the short side first to be fed (landscape)? There is no paper in the machine positioned as landscape except A3 and the manual feed port.
          What did I overlook?
          Hans
          • allan
            RTFM!!
            • 5462
            A3, its not suppose to print on A3 except if someone is sending you A3 faxes.
            Whatever
            • Hansoon
              • Sep 2007
              • 3402
              My bad: Forgot to mention that the problem is with the TX-report, normal faxes are being printed on the selected cassette. Edited the post accordingly. Sorry 'bout that....
              Hans
              • Hansoon
                • Sep 2007
                • 3402
                Think I found it:
                Solution ID 2 Solution Usage TAUS0700459EN*
                Description
                What settings are necessary to choose the paper tray that the TX Report prints from?
                Solution
                The tray that the TX Report prints from can be selected using the following steps:
                1. Press the Utility/Counter Key.
                2. Select User Setting.
                3. Select System Setting.
                4. Select Paper Tray Setting.
                5. Select Print Lists.
                6. Select the paper tray that the TX Reports should print from.
                7. Press OK.
                8. Follow the prompts to exit back toa normal panel.
                Hans
