C284e - J32-01
  • JDR
    • Jan 2015
    • 82
    C284e - J32-01
    Hi dudes,
    did anyone had this random J32-01 trouble with a C284e ?
    In a duplex job, the first sheet goes out of the MFP instead of going upside of the exit unit.
    I've replaced SD3, tried to cut both springs in the paper exit unit(solenoid SD3 + gate) but it only works few days.
    no idea where to look for.
  • allan
    RTFM!!
    • 5462
    Re: C284e - J32-01
    http://www.copytechnet.com/forums/ko...highlight=3201
    Looks like it is a sticky noise damper on the gate.
    Whatever
    • JDR
      • Jan 2015
      • 82
      Re: C284e - J32-01
      i had cut the spring guide but definitely not by half.
      I will try and tell you.
      • SAR
        • Jul 2009
        • 201
        Re: C284e - J32-01
        There's a bulletin on the KM site about inserting a 2mm thick mylar between the end of the solenoid plunger arm and the wall for this model.
        • JDR
          • Jan 2015
          • 82
          Re: C284e - J32-01
          I tried (not with a mylar), but still doesnt work properly.
          Could you send me this TB ?
          • allan
            RTFM!!
            • 5462
            Re: C284e - J32-01
            Do you have the bulletin number?
            Whatever
            • SAR
              • Jul 2009
              • 201
              Re: C284e - J32-01
              Sorry, the bulletin number is KBAO 1500433.
              • srvctec
                Former KM Senior Tech
                • Oct 2009
                • 827
                Re: C284e - J32-01
                We've replaced the sensor on a few machines to fix same jam code also.
                Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                • JDR
                  • Jan 2015
                  • 82
                  Re: C284e - J32-01
                  update : looks like working with all your help thanks.
                  if anyone could send me this KBAO 1500433, i dont have it in my euro km database
                  • SAR
                    • Jul 2009
                    • 201
                    Re: C284e - J32-01
                    Just wanted to update this thread. We still see this problem and they have come out with a new part to fix it. See the attachment for the bulletin.
                    • gareth577
                      • Nov 2017
                      • 7
                      Re: C284e - J32-01
                      [ATTACH=CONFIG]38121[/ATTACH]
                      Are you able to PM me the tech bulletin regarding the j32-01 code, I'm unable to view it clearly within the forum page
                      • SAR
                        • Jul 2009
                        • 201
                        Re: C284e - J32-01
                        Sorry,
                        The part number is A7PU890800 Holding Part.
