Bizhub C253
  • glenbennett
    • May 2015
    • 68
    Bizhub C253
    Hello
    I installed a C253 and programed the IP address I pinged to computer and it found the machine, however when I input the IP address into the URL I cannot find the webpage of the machine, can you help me to find the webpage?
    Thank You
    Glen Bennett
    Thank You,
    Glen Bennett
  • emujo
    • Jun 2009
    • 3009
    Re: Bizhub C253
    If SSL is on you will need to use https://ipaddress
    Another option is HTTP server is disabled through the control panel admin/network settings
    Try a different browser, Firefox may be seeing "weak Delfi-Huffman" key (no points deducted for spelling please)
    SSL Cert, if on may be corrupt. A network init and HDD format (logical) may help.
    Ping the IP address with the cable disconnected..If you still get a reply then you have a duplicate IP. Emujo
      • 14791
      Re: Bizhub C253
      Use Firefox browser. IE and chrome don't work very well with this series of machine.
      • richmods
        • Aug 2013
        • 91
        Re: Bizhub C253
        IE will work, you have to add the copier IP to compatibility view under tools>>>>compatibility view>>>>type the IP in the 1st field then hit add. The page will refresh automatically and should display the copier login page.
          • 14791
          Re: Bizhub C253
          Yes, but way easier to just install firefox once and never have to worry about it again. Just my two cents. Besides, firefox is smoother and less spying than the other choices.
          • richmods
            • Aug 2013
            • 91
            Re: Bizhub C253
            agree 100%. I do however have clients that only have IE on their machine and are not allowed to download anything to their pc due to company IT policy.
            • ChrissyG
              • Jan 2013
              • 30
              Re: Bizhub C253
              Upgrade the firmware of the machine that works for me
