C451 yellow pages
  • dogsbody
    • Jun 2007
    • 289
    C451 yellow pages
    Hi All,
    I have a C451 that covers a page with yellow toner (no leading/trailing edge or side deletions - entire page is covered). Only an issue with colour pages, b/w ok. Konica reckon it's the laser unit, which is on backorder. So i thought i would throw it out there to see what others think. i have changed the yellow image unit and put a second hand transfer belt in on the off chance (wasn't expecting it to work and it didn't). If anyone has any ideas i would appreciate it because I wont get a write unit for at least two weeks.
    Cheers.
    The force will be with you always.
  • redhotrob
    • 69
    How about swapping the yellow write unit with another colour?
    • dogsbody
      • Jun 2007
      • 289
      the write unit for these beasts is one big unit unfortunately.
      Cheers.
      • mrfixit
        Senior Technician
        • Sep 2007
        • 83
        I assume this problem is because the laser always stays on, did you try to cover up the laser unit glass with tape or something to see if this effects any change. wont help fix anything but may help you acurately diagnose it.
        • lanierboy
          • 149
          dont want to get you down, but i had the same on magenta, and we changed
          laser, printer board and mfp board, HV1 and HV2 trans belt,IU, still not fixed.
          in the end sent it back to konica
          • dogsbody
            • Jun 2007
            • 289
            no, top idea, will check tomorrow.
            • richg79
              • Jun 2008
              • 4
              have you tried swapping the laser unit with the cyan or maganta to see if the problem follows the laser unit this work well with the old LED machines to work out if it deffently was that unit at fault before ordering costly parts
              • onlinewolf04@yahoo.com
                color background
                We have had several of these units with this problem. Usually turns out to be loose bias connection in the rear of the machine.
                • dogsbody
                  • Jun 2007
                  • 289
                  Tried this today and the prob went away (along with any yellow image). now just wait for the laser unit.
                  • Gerg?
                    • 67
                    We had this problem with c250, c252 and c203. Changing the PWB HV always solved the problem.
                    • dogsbody
                      • Jun 2007
                      • 289
                      got the laser unit fitted today and all is right with the world.
                      thanks all.
                      • michaelkirby
                        Originally posted by dogsbody
                        Hi All,
                        Cheers.
                        remove the yellow process unit take it apart and you might find that that the charge wire has broken
                        is it a solid yellow copy with image faded into the back ground
                        michaelk
                        • dogsbody
                          • Jun 2007
                          • 289
                          as said, I already tried a complete new IU, in any case replacing the laser was what was fixed it.
                          It was a solid max density yellow, from edge to edge, there was not a white spot anywhere.
                          michaelk
                          • Haroldbfix
                            • 212
                            thanks all.
                            Thanks for the update. I have one that a couple of guys are fighting with this issue now. Very helpful.
