force trays to read o type of paper !
  • jakani
    • Dec 2014
    • 147
    hi everybody
    i have a ineo +454e and i want to ask is there a way to force trays to read one type of paper for example set tray 1 to read A4 paper only and tray 2 to read A3 only
    thank you in advance for any suggestions
  • habik
    • 2013
    Re: force trays to read o type of paper !
    Originally posted by jakani
    hi everybody
    Screw the paper guides in with few self tappers.
    To change it in Service or Administrator settings .. do not recall anything as it is auto-set by the sensors at the back of each cassette or tray.
    What is the primary problem with the machine that you asking this question?
    Firmwares HERE
    • emujo
      • Jun 2009
      • 3009
      Page size is determined by the side guides...only the LCTs (PC and LU) can be only A4/A3. Emujo
      • jakani
        • Dec 2014
        • 147
        thank you habik for replaying
        first there is this one machine that keeps giving 8 1/2 x 11 instead of A4
        and there is other printers shared by many departments so they don't fill the trays with papers , when a user prints something he comes to the printer with three or 4 papers in his hand and play with trays configuration ... so i want to fix the tray 1 for A4 and tray two for A3 and thats it
        • emujo
          • Jun 2009
          • 3009
          Teach them to use the bypass tray for other paper. And if you can't get the MFP to display the correct paper size it may be a problem with the size detection sensors, or a county code mismatch. Emujo
          • jakani
            • Dec 2014
            • 147
            thank you emujo for replying
            i tried to convince them to fill the trays with paper but no one listens and that's another story
            i have one question about the country mismatch how i can change it to use metrics ?
            • allan
              RTFM!!
              • 5462
              By changing marketing area in service mode.
              Whatever
              • allan
                RTFM!!
                • 5462
                But you could have a physical error behind the paper tray at the back of the machine or on the paper tray.
                Whatever
                • emujo
                  • Jun 2009
                  • 3009
                  Regardless of your country code, if the tray is detecting properly, and you are using standard paper sizes, it should reflect whatever is loaded. Size detection issues are usually accompanied with the "???" displayed in the size indication. If you want to be sneaky, and the users aren't very copy savvy, you can remove the paper tray selection options from the copy function list. They will still be available if they open the "application" icon, but from my experience, most will never find it. Now they can't change the paper tray settings (but the MFP will still update itself if LT is swapped out for LG). Emujo
                  • jakani
                    • Dec 2014
                    • 147
                    [ATTACH=CONFIG]31720[/ATTACH]
                    thank you for this great idea i think i'm gonna remove this option in the all MFPs now
                    yes it may be a physical error ; i went today and checked the marketing area to europe and still have the same problem !
